PatShaw
6 Posts |
Posted - 12 Aug 2002 : 16:21:41
Having just bought Stratos 326 (centre board)and basically lost the right to helm, to my wife, who seems convinced that I have bought the boat for her. We are having some rather tense moments when lauching and recovering due entirely to the fact that the rudder is very difficult to raise and lower. Having read one of the previous threads regarding this it would seem that their have been a variety of fittings used in the manufacture of this part of the boat. Please could those of you that have experienced similair problems advise how you have resolved them.
Additionally we sail in a tidal location which can result in the bottom leaping up and grabbing hold of the rudder resulting in damage to the rudder and the boat stopping. Once stopped the downhaul for the rudder has been so securly jammed that it was almost impossible to release. Perhaps the judicial use of a length of shockcord could prevent this from happening, any thoughts about how best to accomplish this.
Cheers Pat
22 Posts |
Posted - 12 Aug 2002 : 21:12:51
Hi Pat I too was worried about grounding the rudder with the standard rudder downhaul in place. I spoke to the Laser service manager who was happy for me to replace the standard cleat with an auto release cleat which ClamCleat supplied very efficiently. The cleat in question is designed exactly for rudder down haul application and "cascades" to release the cleat when the rudder grounds. It is also adjustable. This cleat has worked for me on a number of occations, although getting the blade back down is still a struggle. Because I sail in tidal waters as well, I too find the most difficulty with getting the rudder down and then back up on my return. So far releasing some turns on the rudder blade pivot bolts before leaving the beach, and then tighten again once in deeper water, loosening again as I approach the beach is some help. Would others please advise in detail better multipurchase arrangements. Regards Brian
KevinL
16 Posts |
Posted - 18 Aug 2002 : 20:20:49
Pat,
can you specify the cleat used more precisely or give a link or part name? Thanks
Kevin
PatShaw
6 Posts |
Posted - 19 Aug 2002 : 14:40:58
Brian, This cleat sounds like a mighty fine idea! Could you tell me the exact part number? Did you have any problems in fitting it, for instance is it screwed or rivited to the tiller?
Thanks Pat
22 Posts |
Posted - 22 Aug 2002 : 00:13:15
the cleat I have used very successfully can be found as follows
go to web site - clamcleat.com click on - specialised cleats click on - auto release cleats this shows drawings and details od cleat - CL257 for fitting click on - fitting instructions - and download a drawing of details.
I found the two holes further apart than the standard cleat - so just drilled an extra hole, and then reused the fitting self tap screws.
Hope thsi helps
Brian
22 Posts |
Posted - 01 Sep 2002 : 14:15:46
I have Keel #466 and sail in tidal waters. I too have had problems. The laser service manager was very helpful and suggested the cam cleat solution ( to be fitted - thanks for the fitting tips ), but as a temporary measure I 1) tighten and losen the clamp on leaving and returning to beach and 2) have threaded the ropes through a 3 cm length of plastic hose pipe and jammed the pipe, helped by a cut 'slash' across the pipe, where the ropes leave the metal frame and head towards the cleat. This dramatically improved the sliding across what would have been a severe angle on the metal.
Laser also say that a plastic roller might have fallen out of the metal frame. I don't remember it ever being there ! And if it was it surely wasn't too secure ! I've yet to fit the replacement. |
PatShaw
6 Posts |
Posted - 04 Sep 2002 : 17:04:45
Many Thanks! I have now fitted this to my Stratos, my wife tested it on the hard (accidently) at the weekend and it is a definate winner. Just have to look forward to session of rudder repairs now. |
