 rivets
Jamie
Posted - 09 Apr 2017 :  08:49:40  Show Profile  Reply with Quote
hi i lost the genneker halyard fom the mast so nee to remove the attchment wheels from the mast. ewhat size rivet are used on th mast and whats the best way of rerigging the genneker?
Jamie
Posted - 09 Apr 2017 :  14:03:18  Show Profile  Reply with Quote
I would listen to any other suggestions on this forum, but before I did anything as drastic as removing hardware from the mast I would try two similar techniques:
1) Stand the mast vertical and from some high point e.g. a sailing club balcony, try and feed the halyard down through the mast using its own weight and once at the bottom of the mast try and pull the halyard out using a bent paperclip or similar.
2) using a very light line such as whipping twine weighted with a needle do similar to 1) above and then pull the halyard back through the mast after tieing it to the whipping twine.
I seem to remember having some success using method 2) above.
Good luck!
This page was generated in 0.53 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
