 Second Hand Stratos
neilgbj Posted - 21 Feb 2006 : 12:48:00
I am about to purchase a second hand Stratos.......any tips on what to
look for or any general regular areas of concern (I'm buying anyway
its just so I know how much work I might have to do !)
5   L A T E S T    R E P L I E S    (Newest First)
stratosjazi Posted - 10 Nov 2006 : 16:23:09
Originally posted by neilgbj
Thanks for the replies.............Much appreciated
Are there many boats, racing, training etc in East Anglia ?
neilgbj Posted - 22 Feb 2006 : 19:37:00
riversdoug Posted - 21 Feb 2006 : 16:11:00
Mike,
Only selling as the boys have deserted me into Toppers and are now both in squads, funnily enough I regularly run into Mark West and his crew as their boys are in the same squads. From Stratos to chauffer / sponsor in one easy move!
My sailing club actually presented me with a plaque with a set of pintles attached as a consolation prize. I think you are being very generous with the champion compliment but thanks anyway.
See you around.
Kind regards
Doug
MikeBeggs Posted - 21 Feb 2006 : 16:05:00
Doug,
Sorry to hear you are selling.
You forgot to tell Neil that the only weak points on a Stratos are the
rudder pintles. If your hadn't broken in the Nationals you might have
become Champion. Luckily mine broke the week before the Nationals so I
had fixed it.
The problem is that the pintle pin is held into the aluminium rudder
stock cheeks with a steel roll-pin. The roll-pin is in a hole drilled
right through the pintle. This causes weakness and corrossion, which
breaks the pintle inside the stock. The first you know is when the
rudder comes off in your hand - as happened to Doug when leading in the
Nationals !!!
Check it regularly and replace pin and retain without drilling - I have
fixed a new one in with a grub screw. So far it has lasted.
Mike.
riversdoug Posted - 21 Feb 2006 : 01:01:00
Well I've just put mine on Y&Y website to sell. But unbiased advice! - look at condition of jib and asymmetric. The jib gets tired from being furled and the asymmetric eventually suffers from being pulled into the sock. Both stop you sailing efficiently and the asymmetric becomes almost impossible to launch and recover.
This page was generated in 0.45 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
