 Rudder removal
brian Posted - 27 May 2017 : 11:00:50
Can anyone advise how to make the removal of the rudder assembly easier after sailing. I fnd the pintles very hard to separate form the gudgeons. I have tried oil and silicone but this hasn't helped. It is like the pintle/gudgeon fit is too tight although everything is fine when sailing.
BR
lohr500 Posted - 11 Nov 2017 : 19:18:37
I might try that on ours because I too find the pin very tight after sailing. A trick I did discover was to press in the safety retaining spring clip and slide the whole rudder assembly upwards. This then moves the pin upwards and it is then easier to extract the pin completely.
brian Posted - 27 Sep 2017 : 10:06:37
Yes finally solved the problem by drilling out the lower gudgeon form 9mm to 9.5mm. I suspect some jiggery pokkery by a previous owner caused the problem
JordonM Posted - 30 Jun 2017 : 08:05:55
BR
Hey Brian did you get it off?
This page was generated in 0.34 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
